gattiboy13 Posted November 15, 2013 Report Posted November 15, 2013 Can turning your bass boost up on amp ruin sub? Should this b kept at min?
sbg Posted November 15, 2013 Report Posted November 15, 2013 From what I seen on here, no one uses the bass boost at all. If your gain is set right u don't need to 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Kyblack76 Posted November 15, 2013 Report Posted November 15, 2013 Turn that shit up SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
gattiboy13 Posted November 15, 2013 Author Report Posted November 15, 2013 From what I have heard it can cause clipping which equals coil burning?
Jessica Posted November 15, 2013 Report Posted November 15, 2013 If you have a response curve that peaks at 20 and 80hz and is flat at 45hz then sure, go ahead. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
sbg Posted November 15, 2013 Report Posted November 15, 2013 From what I have heard it can cause clipping which equals coil burning? yes , your boosting the signal more then HU voltage witch = clipping. I may be wrong... 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
08tahoe Posted November 15, 2013 Report Posted November 15, 2013 Can turning your bass boost up on amp ruin sub? Should this b kept at min?Yes it can. Keep it all the way down.
