hx2 power 12 box help plz
alaskanzx5
Just picked it up from a member on here, well didn't know he was a member until he said he was. Said he hasn't been on here for a while but he lives in Indiana and has a Monte Carlo with 218" dd walled. Very impressive build.
anyways, i'm looking for a slot ported box sub up port to the side. Usually I would just throw numbers around on Torres and double check running but don't have my computer right now.
Max dimensions are
19" high
19" deep
40" wide
Looking for a mid 30 tuning, around 34-36hz.
Thanks for the help
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
14" Height
14" Depth
31.5" Width
Port
12.5" Height
2.5" Width
28" Length
Tuned at 35 Hz, L-port on same face/baffle as subs(If you literally meant fired out the side of the box, length of port should stay the same regardless)
Net space 2 cubes and 31.25" of port
Slighty bigger box
Change width to 35.5" and port length to 22" for a ~34/35 Hz tune and 2.5 cubes net
It's a hatchback i'm gonna do sub up port to the driver side.
Those measurement will work great.
Is that a double baffle though?
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I think I'll go with the bigger box to, I have a lot of mid and high compared to 200 rms to that sub. bigger box will hopefully give me more output.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I'll have about 4.5" of space between the port and trunk wall. Sub as for from the port opening as possible rounded off with a 3/4" bit.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I did not figure a double baffle though you can just add it and take away .75" on port length
I'll just add a brace from the port wall to baffle centered the best I can
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Oh, lol... Gotta use my 4 channel for now later i'm gonna get a 300.2 so it won't see over 300rms.
It's just a temp setup until I get the all my stuff here Michigan. once that happens the hx2 will be taking out, the 300.2 will be used for 8" mids and I'll have 2 15" subs on a 1500.1bdcp until I can buy a 2500.1bdcp
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   1 Member, 0 Anonymous, 1468 Guests (See full list)
