hx2 power 12 box help plz
alaskanzx5
I know, I want to do a psi recone for more power and put a t2500.1bdcp on it. Want to see what I can get it to do on a meter.
Want to keep the original dust cap and see if I can get a carbon fiber cone whenever I recone it.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Got back to my computer and got a cut sheet and box designed on sketch up.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
http://southbend.craigslist.org/ele/4160898856.html
That's the one I got, paid $90 for it and the could look fantastic. Still feels new with no rub.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
The Team RF cone of very sexy
You have die exp with the hx2 power series.right? do you think it would handle a t1500.1bdcp at 4 ohms? I see no issue in it. Just an idea for when i'm building a box for my 2 15 after i.e. them here to MI.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Around 1000-1100 if I remember right according to the birth sheet.
Just wasn't sure Because of the speakers age, either way eventually i'm gonna push it past it's limit to have a.reason to recone for more power.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Yeah 1000 probably is a lit for its age. I didn't realize the T1500 put out so much more than a T1000. My T1000bd is rated at 350 for 4 ohms. It makes competing nice though since certain organizations/classes go off of the amps 4 ohm rating.
I say let er rip dude. If you have to recone, do it when it's needed.
yeah, I figured it would be ok just wanted a second opinion on it.
after I get my stuff here to MI ill run it at 4ohm on the t1500.1bdcp until I get a box made for the 2 15"s then wire the hx2 to 1ohm on the 1500.1 and see how long it lasts.
stuff to for the box
1 sheet mdf
wood glue
screws
primer
black paint
blue paint
clear coat
sand paper
liquid nails
router bits
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
