Been messing around with Torres since i got my X-10 and SAZ-1200D to push it with.
Building with 1" mdf and looking to tune it to 32hz, this is the design i keep coming up with as the best option for going into my ext. cab Ranger.
What do you folks think? am i doing it right? any suggestions for improvement would be be appreciated.
'07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I
On 5/21/2015 at 7:07 PM, boom50cal said:
of course he gives no fucks. it's a ford ranger.
only bad mother fuckers drive ford rangers
What's the xmax on that sub? You have a lot port there..
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
30mm xmax @ 70% BL (not sure what that BL means)
I was just asking, I know a 12 with 19mm xmax need about 32" of port area and so it looked like a lot of port for a 10 but it has a lot of xmax on that 10 so it should be good.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Also, what made you wanna use 1" mdf instead of 3/4"?
3/4" will be plenty strong
FI BL18 Build Log: CLICK HERE!!
2003 Explorer Sport:
FI BL18
SoundQubed 2200 at 0.7ohm
Pioneer DEH-2500UI
Pioneer 6 x 8s
Rockford Fosgate 6 x 9s
5 ft^3 box at 35hz
Lots of Mega Mat
SkyHighCarAudio_zpse6b4e501.png3abb2365-8d29-422d-a446-efa7a74b8dba_zps70e62980.jpgFILogo_zps400b37c1.jpg
1" will have less flex and with 30mm xmax its gonna be moving.
that and ive seen 1" mdf for close to the same cost as 3/4"
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I am not sure about the port area myself. It might be ok, maybe email sundown and ask what they recomend for port area. Seeing that the port is so big it has to be super long to get the tuning you want. Here is kind of what you may be looking at when you build your box. This kind of thing happens when you run a small sub with low tuning and lots of port. Keep in mind this isn't the only way to do the port but it is just to show you kind of what you are getting into
pending vehicle port to the side maybe?
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
he could just run the port all the way across the back and still port back, it will only be two bends that way. I just like to keep my port all on one side. Give me a sec and i wil draw that up.
double post
Edited by Markous
  • Who's Online   0 Members, 0 Anonymous, 1667 Guests (See full list)
