Built my first box
oldsoundguy
I am running a RE audio sex10d4 sub in a sound ord sealed box. I want a bit more out of it so I started looking at pre made ported boxes. I needed a box that had a max of 1.25 ft tuned to 34 hz. Its really hard to find a pre made box that is tuned to what you need. So I did my research and decided to make my own box. I went on RE audios website and they have a box building program. I punch in the info and came up with a simple L shape port box that was exactly what I needed. So for 30 bucks worth of 3/4 particle board I built my own.
I just finished it up and got it in the truck and all I can say is WOW!!!!. That makes a huge difference. It sounds cleaner, louder and deeper.
Now when the lows hit the truck vibrates. I think its time for some sound deadener to get rid of the vibrations that have now gotten worse now that's its hitting harder. LOL Its not a bad thing.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Congratulations! Building your own speaker boxes can be a very rewarding hobby all by its self. Hopefully you will get future opportunities to do so. Do you have any pictures of your handiwork?
Also did you use actual particle board or did you use MDF?
Builds:
MDF
80prs
DC 180 alt
out of curiosity what is the black stuff you put on the joints? I assume it is some sort of sealer?
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
I drilled and counter sunk every screw and used THE RIGHT STUFF which is an auto sealant gasket maker, I put it on every joint to seal the box before I screwed it together. What you see is what oozed out.
80prs
DC 180 alt
MDF
Awesome! I was a little concerned when you said particle board, that stuff isn't the best material for making boxes out of.
Builds:
Looks good. Titebond makes heavy duty wood glue. I buy it by the gallon. Keep it up!
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Just a quick update. The box sounds amazing. I cant believe how much better this makes the sub sound. Lots louder, cleaner and you can sure feel it a lot more.
Love it.
80prs
DC 180 alt
  • Who's Online   0 Members, 0 Anonymous, 2936 Guests (See full list)
