difference between a regular box for a trunk and a box for a blow through
waitwhat
but what i meant by is there a different in box design is like does the box go through the hole? and how do you bolt it down? i was told to put threaded rod iirc through the box and the bed of the truck.
Where are you located ??
A blow through is a lot of work for two 12's
well i want and love bass and i have a single cab truck and i want the experience and there is this douche that lives by me that doesnt believe i can do it.
michigan why?
just asking ...
I'ts not that difficult ... just alot of work.
I have a fiberglass bedcover that made mine alot easier.
Mine is actually a "below the window line" wall build with the body of the enclosure in the bed of my truck ...
The enclosure is a simple ported and tuned setup for a pair of 12 inch drivers ... but I have 4 10 inch drivers Isoberic installed ...
The maint thing you have to do is set your truck up so that it will not get water damage. I used Accordian boot between the cab and bed ... worked really well. Then you need to either build a wall setup like mine or design a mouth for the enclosure from the enclosure location to the cab area ...
Please keep in mind that even with just a pair of 12s ... you will loose quite a bit of bed area, especially if you install amplifiers and batteries back there to compliment the sub setup ...
michigan why?
just asking ...
how did you secure the box to the bed?
  • Who's Online   0 Members, 0 Anonymous, 377 Guests (See full list)
