difference between a regular box for a trunk and a box for a blow through
waitwhat
Get an ext cab with proper space and wall it. The next owner won't appreciate the hole you are about to open.
Give sufficient port area. Don't have the subs firing into the port. Those are two pieces of advice. How many subs do you plan on running and what size? Bracing the back of the cab around where you cut may be necessary. Have you ever designed a bandpass enclosure before?
f the next owner!! cut that bish.
What hardware are you going to be running ?
Amp/Subz/Alt
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I would say a 4th order is a 4th order, but I have never done a blowthrough.
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
^^^A 4th order and a 4th order bandpass area two different things though.
A single reflex bandpass is typically what most people consider a 4th order. A normal vented enclosure is also a 4th order, only it's called a bass reflex 4th order. So, generally speaking, a 4th is not simply, just a 4th.
OP, you will want to do a single reflex bandpass style enclosure probably. It will yield the smallest hole you need to cut into the cab. A normal vented(4th order) will be a big hole because basically the entire face of the baffle.
What kind of enclosure style you choose well be based on the subwoofer and what kind of enclosure IT prefers. The EBP, EFFICIENCY BANDWIDTH PRODUCT will determine what sort of environment the subwoofer will like. You may need to do a 4th order bandpass, you may have to do a 6th order. Neither of these enclosure styles are easy to design and typically require tweaking. Most won't nail it on the first or even second try
What subs did you plan on using?
who gives a shit about the next owner. people dont have s10's to worry about resale value.
It needs to be more sturdy and weather resistant just in case anything goes wrong.
750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.
^ DON'T BE A DICK LIKE THIS GUY :)
Team Subsonic Lows
I almost want to like this comment and dislike/relike it up to the point of hitting my daily max likes. Well done Chevy :D
  • Who's Online   0 Members, 0 Anonymous, 547 Guests (See full list)
