Right now I have a single Sa12 in a 2 cube box ported at 32hz with 31.25in^2 of port area. Running on 1250w at 1 ohm from a power acoustik BAMF amp.
The plan is to either upgrade to a single x15 in a 4 cube box tuned to 32hz or add another sa12 in a 5 cube box tuned to 34hz.
Either case my amp will get changed out to a audiopipe 1800.1.
The system is in a 2014 chevy cruze with stock electrical.
Which setup would be louder?
If the box is built correctly, I believe the X could get louder... however two SA-12s would sound soooo much better doing it.
But, if you're over powering the SA-12s... then they would be louder than just the RMS on an X.
Also, 1800watts on stock electrical? >___>
Edited by WhatsAminiTruck
Current: Two SA-6.5s and two tweets in each door powered by an LA-4200, 240amp Mechman Alt, Two Memphis PR12s powered by an SAZ-1500.Waiting on my box to hook up my two SA-12s <3
Well I listen to a lot of rap and decaf stuff so I was thinking the 2 12's would be a better option. I also thought they would have more surface area so they would be louder. But I don't know if that's exactly true.
Thr X has the opportunity to dig lower and with more authority. Louder though....2 12s is definitely more cone area so you COULD get more output with the 2 SA12s.
Either set up will be good, probably about equal output. But your not going to get the power you think you are from the audiopoop amp.
truthsayer
X tuned to 30 - give it more power.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
when you find dependeble 1800w for $300 lemme know right quick PLEASE
  • Who's Online   0 Members, 0 Anonymous, 2742 Guests (See full list)
