2013 Impala: Purchased a couple months ago, needless to say, the stock audio system was no where near sufficient.
The Goodies: Two Alpine Type R D4's. 40ft 1/0 NVX (half blue/half gray) 100ft of NVX 16g Speaker wire, plus another 50 ft of wire for the tweeters, 3 20ft RF RCA's, Audison distrobution block, 1 pair of Hertz Hi-Energy 165XL components for the front, and Hertz Energy components for the rear. RF T1500 for the Subs, and a RF T600-4 for the interiors. 80sq ft of NVX sound deadener. Pioneer 5500BHS 7" Screen, and a Radio Pro 5 harness to integrate everything. Vmax Charge Tank 2500, and a Optima Red Top to minimize the light dim.
Started with runnin the NVX 1/0 Power, and ground front to rear
IMG_0194_zpse0d63a86.jpg.
After the wire was ran, we wanted to see how the Vmax CT 2500 was gonna fit in the wheel well, luck would have it that it was about perfect.
We wanted to fire the subs in, so we needed to see what we were looking at to try and seal off the box.
Most of my car, sitting in the living room
Time to start deadening...
After the trunk was done we need to move to the doors: One reason was to run the new speaker wire to the Hertz Components, and another was to seal off the doors to essentially turn the doors into a seal/deadened box.
More deadening in the trunk, and side walls
Had to build a plate for the 6.5 components to be able to fit where the 6x9's were. (rear speakers)
Time to start building the box! We used 3/4" birch, didnt use MDF mostly because of the weight. Plus I haven't used it before.
Painted the port white to match the car
Carpeted the part of the box that people will see, trying to keep the build as clean as possible the whole way through
Checking box fitment
Subs In
Also made plates for the front XL 6.5 Hertz
Had to modify the pillar panel to accept the tweeters, tried to keep em hidden, just wasnt gonna happen
Onto the Battery/Crossover/Distro Block Holder
Carpeted and kept clean
Nice build, How are you liking those Hertz speakers?
