bcbrassard Posted December 20, 2013 Author Report Posted December 20, 2013 These ToolMaker Batt terminals are great, low cost and i recieved them here quickly in AK. Quality product and looks good doing there job.That all for now until the upgrades begin!
03 Xtreme Fosgate Posted December 21, 2013 Report Posted December 21, 2013 nice packages.. What those terminals run ya? They look good... Looks like you got some RF amp kits as well? Alt should do well,i like the green on the pulley. BUILD LOG-http://www.stevemeadedesigns.com/board/topic/179004-03-s10-xtreme-ext-cab-rf-build/ PHOTOBUCKET- http://s1354.beta.photobucket.com/user/03XtremeFosgate/library/truck%20audio%20rebuild
bcbrassard Posted December 21, 2013 Author Report Posted December 21, 2013 nice packages.. What those terminals run ya? They look good... Looks like you got some RF amp kits as well? Alt should do well,i like the green on the pulley. Terminals where cheap i thought, $30.00 + shipping. I will have to get 2 more to match for the negatives on both batts. These will be the Positives. Great looking and functional product.
alaskanzx5 Posted December 21, 2013 Report Posted December 21, 2013 that's not a bad price at all, when I need some I know who to go with now. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
bcbrassard Posted January 8, 2014 Author Report Posted January 8, 2014 New RF T1500BDCP came in today along with Toolmaker 0 to 4 AWG adapters for power & ground. I have Garage time to install about $3000 of goodies from Jan 16th to the 23rd and will have pics & vids of upgrades. After this is finished time to get a new sub to handle 2000 rms and build a new box, thinking blowthru into rear deck. Thanks for looking, more to come!!!
bcbrassard Posted January 9, 2014 Author Report Posted January 9, 2014 Update or recap of everything going into system upgrade # 3. Front stage: install Kicker Panels & T3s. Install T400-2 for T3s. Electrical Upgrades: Install Singer ALT, Kenetic HC 1800 w/ Toolmaker terminals, RF 0 AWG runs & 4 AWG for mids and highs, and 5 Fuses to runs, Stinger VM, Sub Stage: Remove RF Power 1000a1 and replace w RF T1500BDCP, run 0 AWG power & Ground. Sound Deadener: Rear deck & Pillars, Trunk lid plus acoustic foam. I have about 5 days for tare down & install of all equipment. It should really add to the quality of the system. Substage & enclosure upgrade this spring.
alaskanzx5 Posted January 9, 2014 Report Posted January 9, 2014 Nice 1500.1, almost as good as mine. Birth sheet on mine says 1950 at 1 ohm think the 2 ohm was around 1750 to. Have you seen the new t4 components? They are sexy. Might have to fit them into my budget. along with the new constant power 4 channels, Would make it easier in space since they are small and give an all Rockford constant power setup. They said they still have more press releases with more product updates to come from my understanding. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
bcbrassard Posted January 10, 2014 Author Report Posted January 10, 2014 Thank you. Beast of a little amp! now i need a sub to handle the power. Ya i have been following your RF topic. I hope the put out some subs!
alaskanzx5 Posted January 10, 2014 Report Posted January 10, 2014 There is a vid Mylar posted a lino to check it our t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
