03 RF Lancer amp swap. Punch replaces Power series.
UPDATE ON TRUNK REBUILD.
Temp setup for midbass upfront. No tunes now until rear is done!
Working on layout.
Extended 4 gauge wire.
Card board template from carpet.
Front half for under sub enclosure.
Battery mounting support.
Painting process, not final product.
Wrapped in trunk carpet.
Nice fit.
Adhesion Promoter coat on prepped rear deck panels. Light grey to...
Graphite.
Sub finished. I liked it grey better, oh well.
TOO BRIGHT!
Carpet for a more finished look even though panels will cover 100%.
Rear half panel.
Battery's and fuse layout.
Just test fitting and taking notes.
Been working on it 9 days, still have vertical beauty panel to mock up for behind the enclosure. Amp rack to design and build. Pretty happy with everything just need to get some tunes going again. First time making panels, templates help out big time.
Are you confident that the bolt in the middle of the wheel well is adequate to use as a ground?  If so, that is convenient as can be!
Orion XTR amplifiers
Skar subs
Yes i am. I got lucky.
UPDATES...
I hate the enclosure black...
So i painted it back to grey.
Wire loom showed so i ran it long for now.
Enclosure going back in. Floor panel and Enclosure screwed to the body.
No subs since February....Looking forward to hearing them again.
Second half of floor panel. Painted back side flat black.
Carpet ready..
Prepped ground runs.
Panel installed with grounds leads ready.
Kenetic Battery trays mounted.
Layout complete.
Finished minus power and ground runs to T400x4 & T1500bd amps.
I am thinking about mounting the amps back on the enclosure and build a beauty panel to cover everything but the 2 amps. Original idea was to build a amp rack over the battery's and fuse blocks but it kinda of to pretty to cover up. ?
4 hours ago, bsneon98 said:
looking good man! and I agree with the color of the box. that grey matches nice. What are you using to spray?
Thanks. Rattle can.
10 minutes ago, Crazy 8s Drums said:
Looks awesome so far!
Thanks man.
Finish up wiring in the trunk until i get the amps mounted.
Had to order more Lugs & heat shrink.
Wiring done.
I removed this battery to work on the engine, i had planned on putting it the rear with the others but couldn't find a layout i liked so i threw it back in the engine bay on the other side.  Checked all grounds also.
Amp mounting, and finish up the wiring in the trunk. DD-1 everything and then start on the rear beauty panel to give it a finished look.
