How to set gain on saz3000 when max gain is 6v but line drivers 8v
Deadly hertzz
Please do not cross post.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
After having another thread deleted in another section. Please only post one thread in one section for the same thing.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Ok sir just trying to resolve
My issue, I usually have good luck on smd with advice or
Giving advice but this time I'm just having another user give orders rather than give help, but thanks for your concern
8 sundown sa 12s walled
Saz3000 at .5
HO alt
All ofc Sky high wire
Alpine components
Rockford power mids
imagesCAA9EA5N_zps0f411022.jpga5ec9a01-b60c-4312-9001-236b48dfe6b0_zpsb01ef146-7fd0-47c3-90e9-f1a2d4595b03_zpsimagesCATNMRMV_zps66a8566a.jpg
Hey sparky. Im a moderator. Its my job to do what I just did.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Set the deck first. Find the maximum non-distorted output and record that number. Might be something like 47 out of 50 (for example.) If it is, leave it at 47. Now with the line driver plugged in, turn it up while looking for distortion. Once it distorts back up just a hair. Now take a DMM, put it on A/C and check the voltage. If it's 8 or 9vac like you say it is, then turn it back till it is at 6. Usually, i set them to 5v but 6v is ok too if that is what you want it. This is all assuming the thing is clean till that point. For all you know, it is clean until 3v. Audio Control is good stuff so it probably is clean till at least 5v.
Anyhow, lets assume the line driver is clean at 6v and the deck at 47 out of 50 (still an example). Leave it all turned up just like that and then adjust the amp gain accordingly. Once you are done with that your gains are set and you are done. Chances are, if you are pumping 6 CLEAN volts into that amp, you might not be turning the gains up at all, maybe a hair. That is a good thing though!
Follow my Tweet (Twitter)
Oh and please don't get smart with n8. He is one of the very few here who has enough power to delete MY account....so have some manners, it will get you a long way. Being rude and getting smart will not. Thanks!
Thankssss for the help! Been trying to set this amp for a couple days now without deleting the line driver from the equation, didn't know it was a prob with the 2 threads won't post 2wice again
Saz3000 at .5
HO alt
Alpine components
Rockford power mids
  • Who's Online   1 Member, 0 Anonymous, 1020 Guests (See full list)
