oldsoundguy Posted November 27, 2013 Report Posted November 27, 2013 So I have a mono amp with input and output to connect another amp to it. I also have two sets of RCA outputs on my HU to run the two channel amp and mono amp. Is there any difference between running RCA from amp to amp or from HU to each amp? Any more control from the HU? Thanks for the help. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
hazestorm23 Posted November 27, 2013 Report Posted November 27, 2013 Its made so that you can run more amps without the hassle of running 2 runs from your head unit to the amps. As far as iI know its OK to just do one run to amp and then jumper RCA's to other amp.
