Regular Cab truck Box
Yuck! Please stop with the 6x9s! you wont hear them behind the seats. Concentrate on the sub box and what you want behind the seat, Get some really good 6.5 comps for the doors and if thats not enough then look into some kicker panels. I know you have an idea in your head but listen to others and there advice. Good luck! Just my 2 cents!
Would this work?
yeah the 6x9 idea it stupid I can't even hear mine 5 1/2 I think in the bottom back with the 10's
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
I would run the tweeters in the front because the bass will drawn the tweets out if they where facing behind you
2 sundown sd-2 d4
flex tech
box design by Joe X
ok i think we got it figured out
2 4" midrange speakers mounted up high for listening to country and music with no bass.
Either 2 e-10s or 2 sd 10s depending on which is better and if its worth the price difference.
Rockford Fosgate prime 1200.1
and a custom ported box
If i use a 5" round aero port where do i put it. If i put it on the side i feel like it will hit the driver. Could i use 2 ports half the size? Will the seem to hit harder if the ports are out in the open. if it is on the side i feel like it would make nise since the port (if on the side) would be around 1 inch from the wall of the truck.
You need to leave room for clearance of the port opening and Amy obstacle, I.e. B-pillar. You would need to take width away from the box to allow the port to clear. I've got two 4" ports firing at the B-pillar and it sounds perfectly fine. It acts as something for the port to load off of and I have proper clearance so there isn't any noise.
You need a box design from someone on this forum. Ask JoeX our someone like myself in PM, AND I'LL be happy to help get you a design. You also just need to hear a truck with a box like this, they sound great
  • Who's Online   0 Members, 0 Anonymous, 1083 Guests (See full list)
