Guest Posted December 2, 2013 Report Posted December 2, 2013 input level = gain. same thing. that .4 amps you're talking about is the remote turn on lead. that wire turns on your amplifier when the sony stereo turns on. input level is adjusted to how many volts the preouts (rear audio out) on your sony put out. usually its like 2 volts, or 2.5 volts, sometimes 4 volts. depends on the stereo.
[email protected] Posted December 4, 2013 Author Report Posted December 4, 2013 Thanx dude, soo. what i do is that i set my gain by ear with 40hz tone, and the loww pass filter at 80-90hz i think.. and bass boost in +2 almost all the way down.
hazestorm23 Posted December 4, 2013 Report Posted December 4, 2013 Bass boost 0. You shouldn't have to boost bass . It sets you up for clipping and that's no good. If you set everything else accordingly you shouldn't need it
gattiboy13 Posted December 4, 2013 Report Posted December 4, 2013 Bass boost should be at 0, is what I have learned. And your Low pass filter on amp should be around 70-80
[email protected] Posted December 4, 2013 Author Report Posted December 4, 2013 Okkk, soo, bass boost going to 0 , and i will tweak the low pass filter. to 70-80hz
twisted1 Posted December 4, 2013 Report Posted December 4, 2013 No way to know where 80hz is! Like I said the cc1 can set it but it cost more then ya amp You can youtube the lil formula for setting it with dmm 09 mustang gt
[email protected] Posted December 5, 2013 Author Report Posted December 5, 2013 Okkk soo now it sounds cleean, but i dont have the same amaunt of bass as before, is good to set in my radio the bass in +6 of 10'??
gattiboy13 Posted December 6, 2013 Report Posted December 6, 2013 Yes use your head unit EQ to adjust your bass level, and as for the bass boost on head unit I would not go more than +2
