*sticky* Free Tech support
Double checking...if I have 5 30amp fuses between both my amps, I use a 150amp fuse on my main power cable correct?
1998 SS/T Ram Build Log
- Kenwood KVT-514 and KNA-G510 Navigation
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- Second Skin Dampy Pro
- XS D6500
What size power cable? 1/0?
For 1/0 id use a 200
For 4awg id use a 120
Thats if the run is roughly 13-14ft
Yes, 1/0 awg and the run is about 12'. Then split into 2 12 inch runs of 4awg.
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- XS D6500
200 is fine.
Hell anything between 125-250 will be fine
Ok so you are about the most knowledgeable guy with the sub boxes. So i kindly ask for your support and thanks in advanced for the advice. I have a sub sox i plan on building, Specs are H24xW40xD24 The port is H22.5xW5xL27 This port is in the middle of box in between subs. So my question is how far back would the port go before having to split left and right? Also how far left and right would be the port keep extending? I will also have 45's at the back of the port
Thanks Ray! :drinks:
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- XS D6500
Port board going back is 17.5 long then they turn 3"
My engine temperature sensor gives false readings. I know this because the gauge on the dash rapidly jumps to the Max temp and back to normal. 91 CHEVY. 4.3
Look to the left of where the brake pedal rod goes through. From the inside.
You will see a perforation in the padding on the firewall.
oh ok thanks for your help bro!
another question.
WOuld i be able to go to an autoparts store to have a hole drilled??
i don't have a drill kit of my own.
