*sticky* Free Tech support
Common to have bad instrument cluster.
Go to a stereo shop and have them pop a hole for you
Yes 3" left and right.
Yes start at side of board going back. Need to keep 5" throughout
Im planning on glassing my doors and rear deck in my car to make custom mounts for speakers, my question is what kind of resin and matt should i use and where could i get it? i have lowes and home depot near me...
Thanks Ray.
2 DC 12" lvl 4s
1 DC 1.2k
XS Power S3400
big 3
Alll KNU wire
Pioneer HU
cheapo Legacy coaxes (just for now)
Hey ray where would I run my power wire in my firewall?
Can't seem to find an existing hole I can use.
It's a 2001 eclipse gs and I'm trying to run just a single run of 0 gauge
Would I have to drill a hole? Last thing I would do.
If I do have to drill a hole where would I do it so I wouldnt drill anything important.
You can get a signal with almost any deck on the dd1.
Ive only seen 1 issue and it was only because i was using a -15db track with a "Y" ed rca
On a 1v output pos.
As for the hot start
Could be lots of things
Is it cranking over? Just no fire?
Distrubitor is common.
So is iacv
I just saw that.
Was a strange issue.
Constant was touching ign behind the radio.
This causes no start because the deck constant shares the power feed with the ecu
Same fuse under the hood.
Its a 7.5amp
