*sticky* Free Tech support
what do you need.?
yeah i can help you..
do you need wiring info or what?
if im correct your truck in an 2002 or down.
if so here you go.
12volts
red
ignition harness
Starter yellow + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition white + ignition harness
Third Ignition N/A
Accessory orange + ignition harness
Second Accessory brown + ignition harness
Keysense lt. green - ignition harness
Power Lock lt. blue + brown plug at BCM
Power Unlock white + brown plug at BCM
Lock Motor gray 5wi driver kick panel
Unlock Motor tan 5wi driver kick panel
Parking Lights+ brown + lt. blue plug at BCM
Parking Lights- white - lt. blue plug at BCM
Hazards
Turn Signal(L)
Turn Signal®
Reverse Light
Door Trigger   - BCM
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm lt.green - driver kick panel
Disarm No Unlock
Tachometer white ac ECM
Wait to start dk. blue - instrument cluster
Brake Wire white + brake pedal switch
Parking Brake lt. blue to green/white - parking brake switch
Horn Trigger black - brown plug at BCM
Memory Seat 1
Memory Seat 2
Memory Seat 3
if you need me to go into detail it will have to wait till tonight.
I need help installing a alarm into my silverado. The viper791 xv. With remote start. I had an older alarm that had remote start alredy. But I broke the remotes and can't find replacments.  Here's the wireing for it http://www.directwholesale.net/diagrams/di...ams.asp?link=DW
Can you help me out?
what do u need help with/ that site even gives u pix with captions to tell u where and how things come apart and which wires to tap into........
  • 1 month later...
I have a Q for ya RAY:
I have a Alpine deck from around 2002
I have a PG Tantrum 600.4 runnin MB Quart 5 1/4's up front and the 6 1/2" 2 way rears.
Here's the problem: It has been fine forever since about '02 when I built it all, and just recently the passenger side mid& tweet (both filtered by one musicomp xover) will cut in and out. Sometimes when it cuts out the volume will be med-low maybe 18-20 out of 35 and if i turn it up the passenger mid will kick back in, but not always.
I swapped out the xover No change. Swapped out the midwoofer, still no change. I had a similar prob w/ my 1st alpine deck and couldnt tell what the deal was but then I got a newer alpine deck and it seemed to go away for a couple yrs.
I have not tried a new amp on it but I could cuz I have a 2nd 600.4.
My bro said it could be the tweet (only speaker in the equation i didnt swap out) could be causing an impedence conflict or somehow the voice coil could be "out of the electromagnetic gap" (I guess it could but i dont think it would cause this) and then turning it up provides enough voltage to "jump" the gap and it comes back on? I dont think thats it but he said maybe so i'm throwin it out there.
My guess is i just need to swap out the deck like it's a deck issue. I hope thats it cuz i already have a new deck for my car and once I get my ipod cable it will be swapped.
So i guess my Q is have you heard/any exp w/ a deck output doing this? Or is it more likely the amp or somehow the speaker(s)?
Thnx in advance.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
flip flop the rca's at the amp ........... left to right and vice versa..
lmk
Ok-that's why you're THE Ray.
<--deedeedee. I should have tried that.
ok so I did that. same ish mayne.
It fades in and out.
I swapped the deck.
Same shit.
I'm thinkin:pinched/cut rca comin apart under the carpet, or bad amp??(god i hope not bad amp i love those amps and i was gonna run em in my next build but all 4 of em)
Any more possibilites i'm missin here?
Thnx in advance man i cant find this thing but i'm dreadin a bad amp channel.
ok so you swapped l/r rca's.. and the same speaker was doing this??
if so swap the speaker wires at the amp and tell me if it changes sides..
if so then its your amp, if it stays with that same speaker then we have a good one here....lol
lmk
