*sticky* Free Tech support
NO ok thats my fault i said it wrong.
I did like u said, which i should have thought of but i'm retarded apparently.
I swapped the L/R rca's at the amp and the fade-in/out moved with it FROM passenger TO driver.
Then new deck w/ rca's swapped sides and same fade-in/out on same side as swapped the 1st time (driver), then swapped em back at amp and it's back to start on the passenger side.
Ghosts?
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
You have a signal problem. bad solder termination at the end of an rac probably.
just run some new ones and be done with it.
Your welcome
I was thinkin a bad rca could be it like pinched or cut somehow but dint wanna rerun a new one. I guess I gotta try it I sure as hell aint tryin to scrap my amp or do a swap for th eother 600.4 right now.
Ray= superhero. TY.
you could just y the good rca, if you want to double check it just run them over the seats and make sure thats it..
allright off to some audiocontrol training.. Ill check back later
Ok I'm retarded twice.
I guess it wasn't the rca. I pulled out the PG twisted pair rca I THOUGHT wa the prob.
I picked up a new JL rca.(decent quality IMO)
Same shit.
I checked output AT the amp....bingo.
as I'd feared dead front right channel. (Like i said it fades in and out)
So...=gay. The suck.
Tech I have another amp but for now I swapped the rca's at amp so front=rear and vice versa and swapped speaker connects to the same.
So i basically just isolated the problem and moved it to the rear fill which i generally have turned way down anyhoo.
Band-aids FTW. I swap the amp out later or just wait till i do a proper rebuild.
But DEEEEEMNIT! :ranting2:
Thnx again Ray.
:poster_stupid: :shiftyph34r: :love: :love: :love:
Guest MegaloManiac
WEDNESDAY  :whistling:
:W:
  • 3 weeks later...
OK-not so much "tech support" but more of an exp/opinion for Mr. Ray:
Knowing that you dealt with planet Audio at Superior, did you have any exp w/ the Vortex series subs?
In particular the VPX108 dual 4ohm 10's.
Just curious.
  • 2 months later...
Ok, I've searched and searched and have yet to find the answer to this ?. How do I figure out how to tune my box? I know that there are programs and such that you can use. But how do pro's like Ray and Meade do it? I can't figure it out. I've gotten down the whole cu. ft. part of it, but I want to know how to tune a box if I wanted to do a different kind of port then what is usually used on sites like subwoofertools.com etc.
Thanks,
Andrew
New project in the works ;)
