Looking to buy a pair of HIDs for my '04 Pontiac Grand Prix GT.
Ebay has a 25-40% off on accessories so I figured I'd go about it now.
Would like to replace high and low beam and a new fog light assembly as well.
Do I need to replace the casings? or just the bulbs and run ballasts?
2004 Grand Prix GT
(2) 12" RE XXXs (04/05 XBL^2)
5 cu. ft tuned @ 35 Hz
MMATS HD4000.05
MMATS SQ4100
Infinity Kappa components
Juice Box black cherry
Duralast platinum group 34
1/0 KNU OFC, 2/0 welding
Singer 250A
Just the bulbs and ballasts. I get mine from ddmtuning.com. The 5000k 55w kit with the dualin/dualout harness is my kit of choice, run it in all of my vehicles so far. You only need to replace the entire assembly if they're cracked our clouded over. The 04 and up grand prix headlight assemblies have amazing reflectors so i can only imagine how well HIDs will work in them as far as output and distance. Regardless of who you get the HIDs from, Just get the same bulb number as whats in the lights now and you'll be all set.
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
cool man thanks a lot. I've been having problems with one of my fog lights burning out immediately after replacing. Do the HID kits have a separate wiring so I can by pass my wiring problems with my stocks?
2004 Grand Prix GT
MMATS HD4000.05
MMATS SQ4100
Singer 250A
You can order the relay harness with your kit but it still utilizes the factory harness for the signal from the fog light switch. You can put in your own switch and run it as a stand alone system, but i'd check to make sure you don't have moisture in your lamps, that you don't have corrosion in the harnesses and there aren't any wires grounding out in the harness it self.
Currently Own
2 - DC 5k
lvl 4 motor
lvl 2 motor
right on. I figured It was grounding out, I was going to wire to my own switch because I miss having fog lights. '
Thanks for your help.
2004 Grand Prix GT
MMATS HD4000.05
MMATS SQ4100
Singer 250A
You need projectors too.. please...
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
not a problem, having an 02 and an 06 in the family helps sometimes haha
Currently Own
2 - DC 5k
lvl 4 motor
lvl 2 motor
projectors?
2004 Grand Prix GT
MMATS HD4000.05
MMATS SQ4100
Singer 250A
low beam-9006
high beam-9005
fog-898 but in hid you need 880/881 their the same base
http://www.ebay.com/itm/35W-12V-AC-HID-Xenon-Digtial-Slim-HID-Ballast-H8-H10-H11-H13-881-880-9006-H7-/271227126098?pt=LH_DefaultDomain_0&hash=item3f26658152 x6 thats for low,highs, and your fogs this is the ballast
and here you get the bulbs each one is a pair
http://www.ebay.com/itm/HID-Xenon-Replacement-new-Bulbs-H1-H3-H4-H7-H10-H11-9005-9006-9003-898-4300K-/280778407252?pt=LH_DefaultDomain_0&var=&hash=item870e274cee
go with Gadgetmalls on ebay $46 buck each kit contact the guy for the ac ballast set or just click the add to cart the 35w bulbs then add the 35w ac ballast x6 I got the kit for my sister car 2005 altama and they been working for 3 months now with no problem I used 9007 harness becuase I got a 3 of them just sitting it the same stuff that ddm uses and only 5 day to your door. I order a set from ddm for a buddy it took 4 weeks to show up at my door.
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
  • Who's Online   0 Members, 0 Anonymous, 1101 Guests (See full list)
