a21cuda Posted December 1, 2013 Author Report Posted December 1, 2013 do you have rca's going into your amp?Yes, I have rca's going into my amp. plug those rca's into the dd-1. also, set the amp with the -5db track. Do you have this burning coil issue with the car running or car off? Are you sure you don't have the coils wired out of phase? Do you just plug them into the DD-1 one by one? The burning coil issue is with the car running and driving, and I'm almost positive I had them wired the way they are supposed to be, in parallel.
a21cuda Posted December 1, 2013 Author Report Posted December 1, 2013 do what i asked. report back with results. Okay, I will.
Jessica Posted December 1, 2013 Report Posted December 1, 2013 just plug one rca into the dd-1. no need to check both. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
a21cuda Posted December 1, 2013 Author Report Posted December 1, 2013 just plug one rca into the dd-1. no need to check both. And then you just play the 1khz track and turn the Headunit volume up until it shows distortion?
Jessica Posted December 1, 2013 Report Posted December 1, 2013 yep Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Guest Posted December 1, 2013 Report Posted December 1, 2013 just plug one rca into the dd-1. no need to check both. And then you just play the 1khz track and turn the Headunit volume up until it shows distortion? if thats what the instruction booklet says.
a21cuda Posted December 1, 2013 Author Report Posted December 1, 2013 Is it possible for the coil to be burning on the -10db track that I set the gains with, it with that showed no distortion? That's what is weird to me, that it would smell like burning coil on the track that I set the gains with.
SnowDrifter Posted December 1, 2013 Report Posted December 1, 2013 If you play something with a bass line louder than -10db, your amp will clip. Clipping creates heat, heat makes the smell. So yes it's possible. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
slowfkncar Posted December 1, 2013 Report Posted December 1, 2013 Enclosure size Subwoofer impedance Subwoofer size Head unit type Source of music...?
a21cuda Posted December 1, 2013 Author Report Posted December 1, 2013 Enclosure size Subwoofer impedance Subwoofer size Head unit type Source of music...? Enclosure is a Subthump sealed console box with polyfil, that is 1.16 cu ft., which is within spec of kickers specifications, 4 ohm impedance dual voice coil 12 inch Kicker L7 Kenwood Excelon KDC-X496 Head Unit USB cable to my iphone is my source of music, and all of my music comes from iTunes.
