My small build , "New Focal component set" Pg 89
Looking good, when is the new sub suppose to ship? You build has come a long way since the banging system to the Kick ass SQ system.
Thanks man.
I believe it has a 7-10 day build time.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Looking good bro !
On a second note, I must say that JoeX  has taught me to design my first box 5 years ago over at another forum, using  formulas and calculation, no program, and since then I have design and built many enclosures for my self and help many others.   A big thanks to Joe !   I was amazed to see he is still doing it !    keep up the good work bro !!
Never Argue With A Fool, People Might Not Know The Difference.
Box update today.
The clear was dry when I got home so I screwed and glued the port , sides, ends, round brace and the 45's in each corner. I also calked all the seams.
80prs
DC 180 alt
Box update.
I took the first baffle and cut out the sub and the port. Then flush trimmed the port to the box. I used my jasper circle jig for the sub hole. I then transferred the cutouts to the top baffle and jig saw cut them just a bit smaller. I screwed and glued the first baffle on the box and its clamped and drying. I will fill the screw holes on the box and get it ready for its finish. I don't want to install the top baffle yet because it will get stained and cleared. I figured it would be easier than having to tape it all off not to get anything on it. I also have a cool idea for a sub trim since the two baffles will be supporting the sub. I don't want to just leave it with the sub sitting on the top baffle so it needs to be trimmed out.
80prs
DC 180 alt
Box update:
Yesterday I mixed up some filler and hit the holes in the front of the box and hit the front and side seems. I only did the sides of the box you will see. No use wasting filler and paint. I did prime the whole box and just got done painting. I used the same paint I used on the dual 12" soundqubed box I built a couple years ago.
80prs
DC 180 alt
Todays update:
I got off work and home by 9am. I glued the top baffle on the box. I let it dry clamped for 6 hours. I then took the router and did a 45 cut on the top edge and port. I stained the top, cut out a trim ring and put a few coats of clear on the trim ring. I will let it dry until tomorrow then I will wet sand it and clear again. I just set it on the box to get an idea of what it will look like.
80prs
DC 180 alt
Box update:
I wet sanded the trim ring with 1000 then 2000 W/D paper. Then I put a couple wet coats of clear on it. Its done and ready for install as soon as its dry.
I put two coats of semi gloss clear on the box and let it dry ( just because I had some left in the can) then I put two coats of gloss clear on the box.
80prs
DC 180 alt
Thanks.
Well it looks like my subwoofer should be shipped on the 28th. I should have it maybe 1st week in May.
80prs
DC 180 alt
  • Who's Online   0 Members, 0 Anonymous, 1756 Guests (See full list)
