ToNasty Posted December 6, 2013 Report Posted December 6, 2013 No. Still not enough (that's my opinion). And if 4.14 is gross then that enclosure is to small. Might try to use 4 instead of 6 ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
ToNasty Posted December 6, 2013 Report Posted December 6, 2013 With that rubicon amp I'd do 4 subs. 3 cubes net with 3 4" aeros or 2 6" aeros ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Slammin sonoma Posted December 6, 2013 Author Report Posted December 6, 2013 No. Still not enough (that's my opinion). And if 4.14 is gross then that enclosure is to small. Might try to use 4 instead of 6 4.14cu it nets to 3.62cu wich is .6 cu per sub the manufacturer states .5-.75 cu tuned to 35 is recommended so the box is well in spec with the ports i have 42 in2 port area which should be plenty imo mercury milan 1x SA-15 1x db Drive 1000.1d 1x db Drive 80.4 nexus 7 in dash fosgate in doors and deck Id imagine youd get alot of help if you posted in the right section
ToNasty Posted December 6, 2013 Report Posted December 6, 2013 If there the v2 then they need .75. Plus our under powering a ton if your running 6 with that amp. ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
nCOMP1337 Posted December 6, 2013 Report Posted December 6, 2013 are you going to be sealing this off? you said a wall type with the 40/60 seats, so will you be sealing the trunk? if you do seal the trunk, ports firing forward would be best
ToNasty Posted December 6, 2013 Report Posted December 6, 2013 And 2 4" ports is only 28" or port. ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Slammin sonoma Posted December 6, 2013 Author Report Posted December 6, 2013 If there the v2 then they need .75. Plus our under powering a ton if your running 6 with that amp. they are ev.3d4s 300w rms x 6 subs = 1800w rubicon 2500@1 1700@2 1000@4 ive thought all this out box specs, batts , amps ,subs, space....im going with low watt 8s for electrical reasons....im going with the e series for box reasons....im doing rubicon cause my friend is selling 2 of them for a great price (he never used them) mercury milan 1x SA-15 1x db Drive 1000.1d 1x db Drive 80.4 nexus 7 in dash fosgate in doors and deck Id imagine youd get alot of help if you posted in the right section
ToNasty Posted December 6, 2013 Report Posted December 6, 2013 Ahh ok. I still wouldn't use 6 3" aeros. If anything I'd use 3-4 4" or 2 6"s. I can't remember were but I don't think you want a bunch or aeros for a daily box ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Slammin sonoma Posted December 6, 2013 Author Report Posted December 6, 2013 are you going to be sealing this off? you said a wall type with the 40/60 seats, so will you be sealing the trunk? if you do seal the trunk, ports firing forward would be best i planned to attempt a seal not sure how to seal it that was going to be my next thing to research mercury milan 1x SA-15 1x db Drive 1000.1d 1x db Drive 80.4 nexus 7 in dash fosgate in doors and deck Id imagine youd get alot of help if you posted in the right section
Slammin sonoma Posted December 6, 2013 Author Report Posted December 6, 2013 Ahh ok. I still wouldn't use 6 3" aeros. If anything I'd use 3-4 4" or 2 6"s. I can't remember were but I don't think you want a bunch or aeros for a daily box good point but ive tried tuning with 4 4" ports i need about 30" of length to get it to 40 an my goal is 35hz mercury milan 1x SA-15 1x db Drive 1000.1d 1x db Drive 80.4 nexus 7 in dash fosgate in doors and deck Id imagine youd get alot of help if you posted in the right section
