Diamond500 Posted December 6, 2013 Report Posted December 6, 2013 I was looking into put a H22 Engine into my 2000 Honda Accord LX(Automatic). Called up one shop that does swaps and told me they couldn't don't it because the computer wouldn't work or match up to my car and wouldn't run right. Is that true or the shop just doesn't want to do that kind of work?
RooTxBeeR Posted December 6, 2013 Report Posted December 6, 2013 Did you only try and call that ONE shop or did you try any others? On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Diamond500 Posted December 6, 2013 Author Report Posted December 6, 2013 I only called that one shop because it was closer to me. Just wanted to double check before calling every other place out here.
RooTxBeeR Posted December 6, 2013 Report Posted December 6, 2013 I would think calling other places could possibly get you a faster answer than waiting for a reply on here. Just my .02. I wish I knew engines more but I don't :/ On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
bcbrassard Posted December 6, 2013 Report Posted December 6, 2013 It doesnt sound right to me. Engines and engine. CPU would detect new motors opterating functions and adjust. Or code it out if something was wrong. As long as the motor swap is close in year & engine series.
rsxguy Posted December 6, 2013 Report Posted December 6, 2013 you should be able to do it people swap those into a lot of cars same with the k20 you should look on a honda forum there will be alot more info on the swap
Qiraat Posted December 6, 2013 Report Posted December 6, 2013 Ur probably gonna need the puter harness from a auto prelude
RMac18 Posted December 6, 2013 Report Posted December 6, 2013 ECU:OPTION 1: Keep obd2 by finding a 96 h22a ecu. This ecu has no immobilizer in it so its basically plug and play.OPTION 2: Convert to obd1 by buying a conversion harness (same as the 00 gsr) then plug up a p13, p28, or any other compatible ecu.This is what is posted as far as a h22 swap in a 6th gen(90-02 Accord) as far a ecu options on honda-tech. If you check the forums there under the 6th gen section theres a h22 swap info that tells you what parts you'll need for it and the options for it.
Diamond500 Posted December 6, 2013 Author Report Posted December 6, 2013 Alright thanks guys that helps a lot. Called one more place and they wanted $4000 with the engine. Little more then i expected and they told me the immobilizer was the tricky part.
