Cody Johnson's F-150 8 15s 4th order
Cody, this turned out great but I'm trying to figure out your box dimensions. Can you post the measurements or tell us how many cubic feet the ported side has? I'm sure this will be a demo monster, I am just curious as to how you two got 8 15's in a fourth order in the back of your truck.
2001 VW Passat Sportwagen
Alpine ICS-X7HD
DC Audio 5K
SSA 15" XCON
Tantric Sounds 6.5HD's, Sundound Audio SA-6.5CS
Incriminator Audio IA6.4
XS batteries, KnuKonceptz wirez, Second Skin
Numbers I want numbers !!!i know it does a 55 I know u don't care bought numbers but I'm curious
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
^^^ and videos!!!
Alpine ICS-X7HD
DC Audio 5K
SSA 15" XCON
Dimensions are as follows.
Width- From door to door.
Height- From floor to roof.
Depth- Stupid fucking ginger took my damn leg room!
FUCK NUMBERS!!!!!
If I ever get pissed off and want to build for numbers, yall ill see me use the shell I have here and build it back down to 4 15s and put a fuck ton of power to it with a driver side port.
FUCK NUMBERS!!!!!
Word. Post some vids! I wanna see this get down and put a hurtin' on your truck and some people.
Alpine ICS-X7HD
DC Audio 5K
SSA 15" XCON
I am slowly getting it finished. I was able to find a pair of Singer 320A 6 phase so I can finish my triple bracket. The mechman wouldnt work. Their regulator plug is on the lower right side and hits my air intake.
cant you unbolt the case and turn it around? i remember doing that years back to my truck
Singers nice!!!!!
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
