Aj11 Posted December 13, 2013 Report Posted December 13, 2013 will a 136amp alt be able to charge 2 batteries? have 2 type r 12s on 1000w rms jl /v2 amp. 00g wrire and big 3 done with 00g wire also. plan on putting another battery in tee back near the amp just want to make sure my alt can handle it. its brand new one month old. thanks for the help guys jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
evermaxx Posted December 13, 2013 Report Posted December 13, 2013 Just charge your battery when it gets low. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
graham0599 Posted December 13, 2013 Report Posted December 13, 2013 Just keep a maintainer on it at night or charge every week or 2 My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678
Acme Tops & Tunes Posted December 13, 2013 Report Posted December 13, 2013 At full tilt your amp draws 100amps (per manufactures specs) so keep in mind that on top of this 100amp draw from your JL amp, your vehicle will also be pulling what it needs for your OEM electronics. I would recommend to upgrade your alternator but I'm sure the 136amp alternator will do ok on your batteries as long as you are not constantly playing your system with the vehicle off and you have a proper battery isolation setup so the 2 batteries will not be trying to charge each other/pull current from each other. Acme Tops & Tunes 6430 Franklin Blvd. Sacramento, CA 95823 www.acmetopsandtunes.com PH 916.429.2293 FX 916.429.2296 Facebook YouTube Twitter Yelp Google
Aj11 Posted December 14, 2013 Author Report Posted December 14, 2013 i never bump with the car off! so your saying i should be fine if i get a isolation setup? jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
n8ball2013 Posted December 14, 2013 Report Posted December 14, 2013 Dont bother with an isolator. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
deathcards Posted December 14, 2013 Report Posted December 14, 2013 Dont bother with an isolator. this skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
Aj11 Posted December 14, 2013 Author Report Posted December 14, 2013 no? just run run the 2 at a 12volt charge and all should be fine? I've Done allot with car audio in my life but never a second battery. i Just want to make sure I'm improving my system and not causing another headache. the batteries will be connected by 00g wire, and should there be a fuse inbetween them? of course there will be one from the second battery to my amp,but should there be one inbetween the batteries? if so how big of a fuse? thanks for all the help guys! are rv batteries any good? every kid i talk to where i live say get a rv battery but I've never heard of doing that jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
deathcards Posted December 14, 2013 Report Posted December 14, 2013 no? just run run the 2 at a 12volt charge and all should be fine? I've Done allot with car audio in my life but never a second battery. i Just want to make sure I'm improving my system and not causing another headache. the batteries will be connected by 00g wire, and should there be a fuse inbetween them? of course there will be one from the second battery to my amp,but should there be one inbetween the batteries? if so how big of a fuse? thanks for all the help guys! are rv batteries any good? every kid i talk to where i live say get a rv battery but I've never heard of doing that yes there should be 2 fuses before the fire wall and at the back battery not sure what size i never ran two batteries...yet skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
Aj11 Posted December 14, 2013 Author Report Posted December 14, 2013 i have 2 fuses now, i have a 150anl fuse inches from the battery, and another 120amp fuse by my 4wheel drive on the floor for my volt Meter so that should be fine right? then Just put another 120amp fuse from the second battery to the amp correct? jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
