curiosity 2 amps at 2 ohm or 1 amp at 1 ohm?
alaskanzx5
Say you have a choice of 2 Amps that put out 1500 rms at 2 ohms or a single amp that does 2500 rms at 1 ohm which would you pick And why?
I'm thinking 2 at 2 ohms, would have 3000 rms and at a lower ohm load possible chance of less power draw.
If this is seen as a vs thread I understand and don't mind it being locked. Just trying to figure something out with pinning 2 different avoids up against each other.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Id go with the two @ 2ohm for the obvious reason of easier load on the amps less draw and less strain
2003 silverado TEAM DC
Pioneer Avh 5500
4 DC lvl 5 18s
12 crescendo pwx 6.5s
4 crescendo ft1 tweets
6xs d3400s
Singer 400 alt
Skyhigh ofc wires
Skyhigh speaker wires
Smd vm1
2 DC 175.4
DC 10k
I'd go for the 2 at 2 ohm. Higher efficiency, definitely more wattage for the amperage you'll draw.
Nah man, it's cuz of the bass.
^ my same thoughts, I wont have a lot of room for extra batteries and to stay at a lower class in competitions you have battery limitations. the lower power draw but more power and higher effiency imo is worth it.
I would save roughly $100-200 which could be used for deadener, wire, other car performance parts ect ect..
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
box rise is a real bitch, I know of someone that swapped his 4 5k's at 1ohm each to 2 "6.5k" at .35 or .45 each and gained .5 db on the meter.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
yeah box rise could be an issue, but when the amps im considering put out closer to 1700-1800 at 2ohm and the subs have a 1200rms handling it wouldn't hurt to have some rise. could put it closer to rms for the subs so they live longer.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
i had the same problem. i picked 2amps now I'm adding a Third
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
  • Who's Online   1 Member, 0 Anonymous, 747 Guests (See full list)
