Blown Crescendo 2000d
Jskiles
So this morning i'm driving to work listening to music, then all of a sudden I hear a popping sound and the bass kicks off.I turn the radio off and pull over to see whats up and don't see or smell anything burnt up. Check my fuse in the back and its good, check the voltage to the amp and its reading 14.5v like it should, check the resistance to the sub and its at 2 ohms, but I have an idea why I may have blown the amp. I have a D3400 under the hood, a d925 in the back, positive and negative runs of knu cca 1/0, 1 fuse going to each end of the positive run, But i do not have a fuse between the back battery and amp (didn't seem necessary as it was only a 10 inch run. Dumb ass me) and stock alternator. The amp was run at 2 ohms. I cant look at the amp right now since im at work, but daoes anyone have an idea of what I might have fucked up in this amp?
2010 Kia Forte Koup (Slow Build)
2 Sundown SCV-3000D
2 DC XL M1 with PSI recones
Focal R-165s2 on Orion 4800-HP
Kenwood KDC-X798
Knukonceptz OFC 1/0
Audiotechnix,Fatmat and Q-mat Deadener
XS power D3400 up front 3 D3100s power in trunk
Stock 110 amp alt
2013 Scion TC
2 Dc lvl 3s with xl coils on Soundqubed 2200
Sundown components
AA 50.2 for components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
XS Power D3100 up front D925 in back
Mechman 240 alt
http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build
http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Build
http://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
i dont think the fusing is the issue.
the more important question is how was the gain set?
edit: in reality, just pop the bottom off and give it a look over. could be multiple things.
-10 with dd1.
Here's some other details that may or may not be helpful. My car was running 20 minutes with the radio off to warm up the car. When I was checking the amp it was cold as hell. A couple days ago I had to drive a really ruff ass back road to bypass traffic from a wreck.
2 Sundown SCV-3000D
Kenwood KDC-X798
Knukonceptz OFC 1/0
Stock 110 amp alt
2013 Scion TC
Sundown components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
Mechman 240 alt
-10 with dd1.
for one, you should set your bass amp with -5 or 0db. Very rarely is -10 an ok setting, so you were probably clipping depending on how much you had it turned up. Secondly, the amp being cold doesnt mean something wasnt wrong internally from previous statement, i have had amps pop on good voltage while being cold to the touch from clipping hard for a short period.
Yeah that probably wasn't the best of choices on tuning the amp. Hopefully it will be an easy fix.
2 Sundown SCV-3000D
Kenwood KDC-X798
Knukonceptz OFC 1/0
Stock 110 amp alt
2013 Scion TC
Sundown components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
Mechman 240 alt
yea, it is all speculation until you can really get a good look at everything.
I took the bottom cover off and I dont see anything wrong. No smell either.
http://s1251.photobucket.com/user/Jskiles87/media/VIDEO0006_zpse4dc107b.mp4.html
2 Sundown SCV-3000D
Kenwood KDC-X798
Knukonceptz OFC 1/0
Stock 110 amp alt
2013 Scion TC
Sundown components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
Mechman 240 alt
Can you get a 3.5mm to rca converter and use your phone as a source unit? Trying to rule out anything with the RCAs/head unit
it goes into protect a half a second after it sees power without any rcas hooked up. I even tried it in my house on another car battery I had
2 Sundown SCV-3000D
Kenwood KDC-X798
Knukonceptz OFC 1/0
Stock 110 amp alt
2013 Scion TC
Sundown components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
Mechman 240 alt
  • Who's Online   1 Member, 0 Anonymous, 1215 Guests (See full list)
