Anyone use their battery charger as a power supply?
if its one speaker check the negative on the speaker wire all the way through. if the insulation has worn through and it is touching metal that can cuase a groun loop and cause that speaker ti whine.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Found the problem guys....turns out both sets of my RCAs are shot. When I switched RCAs I only swapped the front set with the rear set. Before I tried the grounding method you advised me I figured I should maybe try a new set of RCAs instead of a different set before I start ripping my HU and amp out. I had a unused set waiting for when I re-install my 3Sixty.2. Plugged them in and crystal clear music came through with no feedback. I still don't know how both sets only caused feedback through that one speaker but no others. Thanks for your advice anyway guys
Do yourself a favor and ground your RCAs to your deck while you are working on it.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 3448 Guests (See full list)
