help with spl 150dbs
and if you get a 149.9 you will be?
three 15's on 7.5k should be able to get you to a 150, I would aim for a 148 with that and be impressed with anything above a 150. just so that its not upsetting when you don't achieve it with so much money and time spent on the build.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
What you arent taking into consideration js material aint free.wood is 34 bucks a sheet for mdf. Even more foor birch. Youre going to rack up a hell of a bill with all these rebuilds chasing a number. Buy once cry once. If you are dead set on that 150 id go right to the 8 or 10 10s and plan for that
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
There are tons of vehicles hitting under 150 that sound damn good, but going for 150 is going to be pricey! It takes ALOT to jump from 140 to 150.
2003 silverado TEAM DC
Pioneer Avh 5500
4 DC lvl 5 18s
12 crescendo pwx 6.5s
4 crescendo ft1 tweets
6xs d3400s
Singer 400 alt
Skyhigh ofc wires
Skyhigh speaker wires
Smd vm1
2 DC 175.4
DC 10k
3 with a ho alt and at least 3 runs of 0 gauge good grounds and big 3 alt to frame ground.
Oh and the biggest battery you can fit under the good.
And that should do good but you might need more batts would at least be a good starting point.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
