Skax Posted December 24, 2013 Report Posted December 24, 2013 Ok so I am totally confused on how to hook this up as I am new to the car audio industry and on yhr back of my radio I see the 2 RCA's for the subs but after that I have no idea how to hook it up at all :/ please help 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
727Designs Posted December 24, 2013 Report Posted December 24, 2013 Get a short RCA to run from the SW RCA out on the HU to wherever you would like to mount the LC-1. Plug those into the INPUT side, get another set long enough to reach from there to the amp, plug those into the OUTPUT side. Simple as that. -Zach-2010 Toyota TundraFull Hybrid Audio SQ 7" BDS on 37's 2000 Ford Expedition 160+ dB Green Turd -SOLD-
Skax Posted December 24, 2013 Author Report Posted December 24, 2013 Get a short RCA to run from the SW RCA out on the HU to wherever you would like to mount the LC-1. Plug those into the INPUT side, get another set long enough to reach from there to the amp, plug those into the OUTPUT side. Simple as that.my thing is there is already subwoofer RCA's running from the hu and jdk where to put it or how to connect both or is that needed? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
727Designs Posted December 24, 2013 Report Posted December 24, 2013 Get a short RCA to run from the SW RCA out on the HU to wherever you would like to mount the LC-1. Plug those into the INPUT side, get another set long enough to reach from there to the amp, plug those into the OUTPUT side. Simple as that.my thing is there is already subwoofer RCA's running from the hu and jdk where to put it or how to connect both or is that needed? Hook those to the output side, then get a short set to run from the HU to the input side. -Zach-2010 Toyota TundraFull Hybrid Audio SQ 7" BDS on 37's 2000 Ford Expedition 160+ dB Green Turd -SOLD-
Skax Posted December 24, 2013 Author Report Posted December 24, 2013 Get a short RCA to run from the SW RCA out on the HU to wherever you would like to mount the LC-1. Plug those into the INPUT side, get another set long enough to reach from there to the amp, plug those into the OUTPUT side. Simple as that.my thing is there is already subwoofer RCA's running from the hu and jdk where to put it or how to connect both or is that needed? Hook those to the output side, then get a short set to run from the HU to the input side.I sent you a pm I'm totally confused :/ 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Skax Posted December 24, 2013 Author Report Posted December 24, 2013 Get a short RCA to run from the SW RCA out on the HU to wherever you would like to mount the LC-1. Plug those into the INPUT side, get another set long enough to reach from there to the amp, plug those into the OUTPUT side. Simple as that.my thing is there is already subwoofer RCA's running from the hu and jdk where to put it or how to connect both or is that needed? Hook those to the output side, then get a short set to run from the HU to the input side.OK I think I got.it now I need to.run a rca male to females cable from hu to sw wires then a female to male in the trunk from end of sw wire to amp? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
727Designs Posted December 24, 2013 Report Posted December 24, 2013 Your LC1 should have female ends on both the input and output. That allows you to use two regular sets of RCA's for installation. One short set from HU to input, one longer set from LC1 to amp. -Zach-2010 Toyota TundraFull Hybrid Audio SQ 7" BDS on 37's 2000 Ford Expedition 160+ dB Green Turd -SOLD-
Kyblack76 Posted December 24, 2013 Report Posted December 24, 2013 Female in, male out. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Skax Posted December 24, 2013 Author Report Posted December 24, 2013 Female in, male out.Im 100% confused as hell there's not spot on the back of my hu except where the sw wires are and how am I supposed to connect them if there is only 1 spot 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
727Designs Posted December 24, 2013 Report Posted December 24, 2013 Female in, male out.Im 100% confused as hell there's not spot on the back of my hu except where the sw wires are and how am I supposed to connect them if there is only 1 spot Unplug those from the HU, plug them into the OUTPUT of the LC1. Then, find another set, plug into the HU where you just unplugged the others from, and plug the other end into the input side. -Zach-2010 Toyota TundraFull Hybrid Audio SQ 7" BDS on 37's 2000 Ford Expedition 160+ dB Green Turd -SOLD-
