How many runs, and fuses.
Kinda confused on what to run and what fuses, and where.
I'll be running,
AudioQue 2200@1ohm
Rockford Fosgate 400.4 or 600.4 (Girlfriend got me one or the other for my birthday, Jan3rd)
Batterys
XS Power 6500 up front
XS Power 3100 in back
Wiring and fuse & ANL Fuses holders from SHCA
I'll be running CCA wire (Hate on it.. I've seen countless threads on it and I dont see a difference between running CCA/OFC at such a high difference)
0 gauge from front to back
0 gauge from back battery to amp
4 gauge from back battery to 4 channel
My question is
1. How many runs from front to back?
2. What size fuse or fuses depending on runs
3. Should I add a fuse to my big 3 from front battery to alt, and if so, what amp
4. Is it nessacery to fuse from back battery to both amps, and if so, what amp
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
You should be fine with 1 run from front to back and then ground each battery to the chassis. Have a fuse within a foot of each batter (250-300 amp). Have a fuse for each amp (choose fuse size according to how much amperage they can pull, it'll most likely tell you what size fuse you need in the manual). I would fuse the alt run with either a 250 amp fuse, but some people don't fuse their alt run.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
How bigd your alt.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
u should be ok with 1 run. i would fuse it front to back with at least a 250, but you can run a bigger one. and grounds...u can never have enough grounds..
Yeah, I thought about doing two runs from front to back, then one run from back battery to amp.
Team Subsonic Lows
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
