NeverTooLoud Posted December 27, 2013 Report Posted December 27, 2013 I am wanting to build a ported/vented box for my 2 15" RE AUDIO SEX15D4's. They require a minimum of 3 cubic feet per sub. They are in my 2004 Cavalier right now. Any tips/help will be greatly appreciated. I have 39" of width between the truck hinges to work with.
Joe X Posted December 27, 2013 Report Posted December 27, 2013 If you even have the space, the box would need to be built inside almost for sure.
n8ball2013 Posted December 27, 2013 Report Posted December 27, 2013 Good luck. Youll have to fire up and build in the trunk. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
TylerParrish Posted December 27, 2013 Report Posted December 27, 2013 What are your max dimensions? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
NeverTooLoud Posted December 27, 2013 Author Report Posted December 27, 2013 17" tall x 39" wide x 29" deep.
n8ball2013 Posted December 27, 2013 Report Posted December 27, 2013 You may want to double check your dimensions. I dont think its 39 wide once you gwt to max height. 36 is what sticks out to me THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
NeverTooLoud Posted December 27, 2013 Author Report Posted December 27, 2013 39 is right below the trunk latch hardware, if it is only 17" tall it should work. The space between the truck hinges are 36" so if it needs to be over 17" tall, you are correct 36" is the width.
Joe X Posted December 27, 2013 Report Posted December 27, 2013 17" tall x 39" wide x 29" deep. It can be done in 17" x 37.5" x 28" if you still have 17" at 28"D and that the 28"D is measured from the top of the backseats slant. Will need to build inside the trunk and you will need to find space for all the stuff you are placing in, amps, etc.
