What's the point????
People everywhere are frantically reconing their subs with zv4 parts. It's pointless to have a motor that only supports 33mm one way and then put 50mm capable frame spiders and surround. It doesn't help a bit. It'll still bottom out at 33mm regardless. I haven't measured it but I would think the coil would be longer on the zv4 as well, which would make the gap between bottom plate a coil less. That would mean it would bottom out in a shorter distance.
Just my rant...
1999 GMC Yukon, 6 PSI platform 5 18's, 4th order bandpass by BHE, Taramps,
Xmech isn't 33MM, Xmax is. So 33MM is just the point that the coil is no longer controlled within the gap. Xmech would be where you see the bottoming out. Xmax is at 70% of BL.
I understand that. But if you take a zv4 coil that's meant for a zv4 motor and stick it in a shorter moto that is capable of 10 mm less. It will bottom out way faster. Example. Hdc3 motor is like half the height of a zv4 motor. The motor is limiting the pros of the frame and soft parts. Waste of money.
But that surround though.....
:peepwall:
Haha! My point. People are willing to degrade their subs performance to make it aesthetically appealing. I'd rather have a sub be ugly and loud. Than pretty and quiet.
