how to go about wiring multiple mids and tweeters?
Skax
when wiring multiple mids and tweeters would you go about taking the wires already running from the current ones and just jump it off or run extra wire to the 4 channel amp or what im confused and same thing about tweeters how would i go about hooking them up if theres no wires for it?thanks so much ;)
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Figure out what amp will run what
Figure out how many tweeters your running and how many mid ranges youre running.
Figure out final ohm load on a channel.
Then wire it up to get that ohm load.
tried to be a simplistic as possible.
i know it all goes to the amp but how would i go about wiring the tweeters/where and same with multiple mids?
im really new to the car audio game idk what to wire where lol
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Take a look at the wiring wizard
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=22
so same way subs go same way mids and tweeters go pretty much?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
then maybe get a professional to do it?
theres no guessing when it comes to loads... wire to low and bye bye 4 channel
IMO when adding multiple mids and tweeters it is always recomended to run new wire to the mids and tweeters especially when you are adding after market drivers that require more power because the factory wiring is small.
You are basically asking us to teach you how to install. Not a problem, good question.
Have you ever hooked up an amp before?
never hooked one up for mids and highs but subs yea ;)
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
  • Who's Online   0 Members, 0 Anonymous, 1234 Guests (See full list)
