termlab help
Bump4life
i bought a used AC termlab.
I am trying to install using windows 7 virtual machine. The software I have is for xp.
i am haveing same issues as in this thread. but when i open instaCal it does not see usb termlab. it says demoboard.
http://www.stevemeadedesigns.com/board/topic/42038-term-lab-problem/
also windows 7 only sees PMD-1208LS under unspecified device list when i search for usb devices.
it seems they changed cord and everything worked? if someone could explain how they fixed it that would be awesome.
both my power and green status light are on. i installed in correct order following every step multiple times.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
go to start right click go to properties and then go to the compatibility tab then select the run in compatibility mode and select the correct package
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
go to start on virtual machine? or windows 7
BMW M340 xDrive
What is your root os? Let me guess you've got a mac huh?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
win 7 professional 64 bit
using virtual machine to run in xp mode sorry for not beiung clear
BMW M340 xDrive
you dont need a virtual you can run it from win7 just use compatibility movde.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i changed it but it is still giving me the same error? should i copy files off the disc first put on computer then try to install?
BMW M340 xDrive
i tried putting files on computer still no luck.
BMW M340 xDrive
  • Who's Online   0 Members, 0 Anonymous, 1661 Guests (See full list)
