Audiopipe 1500 on 24 15s test
Thanks you've just given every broke retard hope that that amp isn't a turd. Now we will see 15 posts about it because they saw it on you tube and it did pretty good.....
All the BS being pushed these days and you comment on this amp lol. Cheap amp yes. Horrible amp no. Not my first choice but still several worse options out there.
I think steve needs to get a hold of this amp and do a amp dyno tueday again
Apcl was on the amp dyno
Cert 526wrms @4 ohm 14v 1% thd
Cert 891wrms @2ohm 14v 1 % thd
Cert 1341wrms @ 1ohm 14v 1% thd
right this is the APSM
My bad I was thinking it was the apcl at first. Can't be to much difference on them. 25-30$ price between the two?
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
i believe the ap series is almost identical to the apsm series.....in size, terminal location, and i read somewhere the guts look the same.....so probably put out the same power.
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
