*SOLVED* *Im happy as balls*CANNOT get wire into my doors...last straw before i'm done....any help? *pictures top of page 4* and first post.
biggest key here is the hole isnt big enough otherwise running the wire through would be fine.. its making the hole bigger or even making a whole to begin with
Well the other wires will be forced out of the way if there is ANY ROOM. Even a millimeter from each wire could make a difference. :edit: because the lube will give it no friction... (Trying to not make any sexual references here) but even when you think there is no room, a lot of lube will do wonders...
Might need 14ga...
Might need to make the hole bigger or a new hole.
But I'm still 100% success rate with dads technique.
The asshole let me mess around with my passenger door (easier door) for 4 hours in the Florida sun before he taught me how to do it... Then it took 30 minutes a door.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
In my truck I was lazy and just ran wires from my amp to the space behind my head unit. Then I tied into the factory wiring that already ran to my speakers. Sounded just fine... I did it the lazy way because I knew I would be selling the truck to my sister-in-law within 6 months of installation and would just be pulling the gear back out anyway.
On my Scion I did it right. It was a beeotch but I have nice 12g wire running all through the car so I have more room for expansion. To get from inside the car to inside the doors I used a normal metal fish tape. For lube.. not gonna lie.. I spit on that bitch lol. I have been an electrician for almost 17 years now, and although I have access to lube specifically made for pulling wire http://www.grainger.com/product/5ZNP4?cm_mmc=CSE:PriceGrabber-_-Lubrication-_-Lubricants-_-5ZNP4&srccode=cii_5784816&cpncode=27-272446334-2 I can't even count how many times I have used spit lol...
The molex connectors used on cars today absolutely suck.. but most of them have enough room to drill a hole or 2 in.
As for your concerns about using the 18g wire already installed in the vehicle.. at 100W there is no reason that you can't. Despite what some people may say.. that wire WILL carry the current, and there is no way in hell you will burn up that wire with 100W of power.
2006 Scion xB
2 Sundown SA12D2
Ported at 32hz
147 on non termlab (140-142 on TL)
Currently in a walled 4th @ 50hz (not metered yet)
Hifonics brz2100
Alpine Type-S Components
Kicker 300.2
Big 3 / Skyhigh 1/0 cca
Optima Blue Top
3 e8s ported at 32hz
135.1 sealed on dash @ 56hz
135.0 outlaw (I must have chosen song poorly lol)
Build log
'Brandon15zzz', on 09 May 2012 - 3:13 PM, said:snapback.png
May have been clipping but none fucks were givin.
I know man, but its worth a try in my opinion. There are some good suggestions In here... Worst case, I just buy a couple things and you return everything else.
I don't want it to come to that because we need all the bassheads we can get. I can always buy more speakers but bassheads are hard to come by.
You got this man.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Do you guys all think i can get away with running it from back of heaunit to the amp and use factory wire so its half 18 and half 12?
that may be the only option in th eend...or its bye bye time
Not something I would do..... But I'm not the electrician, I'm just a kid who spent 5 years so far learning all I can and enjoying every second of my bass life.
But my factory wire was like 22ga. Either way I'd find a way to brute force it in or cut a hole and make it right.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
so much support is crazy! thanks to all who are trying to help me out in a tough time.
look at me bitching and crying over a damn wire loom. lol
i walled this bitch once youd think running a wire would be easy. The biggest problem is that the grommet isnt accessible through thedash directly, i cant gwt a finger on it!!
I'm not reading through this bible of a thread, but what I do when I get desperate is run the wires to behind the head unit and connect the factory speaker wire to the speaker wire coming from the amp, connect at the harness.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
