*SOLVED* *Im happy as balls*CANNOT get wire into my doors...last straw before i'm done....any help? *pictures top of page 4* and first post.
I can support the last comment. Dad and I have taken care of many doors and it's definitely a 2 person job...
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
trust me you dont wanna use the stock wiring n ghetto riggin it, i had that on my first install, its only going to sound muffled and not the way its supposed to. Threads too long but did you try using a coat hanger?
Current Setup: , 2 Fi sp4 18s in a big ass flat wall tuned to 23hz, Pioneer 80prs, 2 Digital Designs m3bs strapped @ 2 ohms, Banda ICE2000, Crescendo 800.4, 4 PRV 10MR1000s,4 Mclaren MLT300 Super Tweeters Kinetik 2000 XS Power 2700 & XS Power 3100s.
Most cars have cavitys in the kick an wires run in this cavity up high behind dash n8 got it right cause there should be a access offset an using the zip tie should get wire to offset if not use a big unibit an drill as close to parrallel with grommet from inside kick panel
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
waiting on pictures, but some cars have those rods that keep the door from opening too far, if yours have those like mine does, just take that off and the door will swing open more so you can get into the door jam easier.
what do you mean by cavity? maybe pictures will help.
all i know is grommet is tighly packed and up under the dash to where my fingers cant reach and in the door jam i can get any thing in it paralelle.
gogin outside now to get pics
heres the moplex just to show that this isnt the issue and i got the wire through it. its whats between the molex plug and the kick panel of my car. the black hose thing.
pics in a sec.
shows thcickness of metal the grommet goes through
thats how much finger i can get through it through the jam
buried grommet
grommet ie behind all this shit
Picture of hole under the dash. looks tightly wrapped.
Shows the black hose and how i cut it to get more room and to feed the wire...didnt help.
