High note cutting in and out ??? help plz
leonfowler
! have a ab 750.1 at .5 ohms my electrtical stays higher than 13.4 ....i can play 30 to 45 hz no problem but when i get to around 50hz and up ,my amp plays it for a good 3 seconds then output just gets cut in half randomly ...i checked my wiring and subs and everything seems to be good im note sure why my amp seems like it wants to cut off on me on high notes....anyone ever have this problem?
2004 Chevy Trailblazer LT
Walled- 10.5 cubes net tuned 33Hz
2-15 inch AA Team subs D2
Americanbass- 750.1
1 yellowtop under the hood , 4 c&d 88ah batteries in rear
mechman-270
pioneer headunit-4200UB
4 soundqubed supertweeters
phoenix gold 2 channel
back up camera
stinger volt meter
22 years old and still have alot to learn..lets get it
Cuts in half or cuts out completely?
My first thought is that you are tuned low and don't have much rise at 50hz and above so your amp is protecting on the high notes....but just getting quieter? Idk
Team NorthWestSPL
Is the amp going into protect? Where are you measuring voltage?
the amp never goes in protect the output just sounds like it gets cut in half and im wired to .5 ohms ..my voltage stays at mid 13s when it happends
Americanbass- 750.1
mechman-270
back up camera
stinger volt meter
Where is your low pass set at?
i believe around 60-70hz
Americanbass- 750.1
mechman-270
back up camera
stinger volt meter
You may want to check that.... that could be why your "cutting out" up there. You may be "cutting it off" ..... lol
Ya know?
i tried it with it higher as well and it had the same problem i even had it crossed at 100hz at one point ...it would play great at 60 hz then 3 seconds later it sounded like some one turned the bass know half way down
Americanbass- 750.1
mechman-270
back up camera
stinger volt meter
  • Who's Online   0 Members, 0 Anonymous, 690 Guests (See full list)
