High note cutting in and out ??? help plz
leonfowler
yes i have a lpf for my sub on my headunit for 50, 63,80,100
Does your headunit have any cutoff points? My Kenwood has a LP and HP filter setting on it but idk if that could cause this problem? I would assume it could tho.
2004 Chevy Trailblazer LT
Walled- 10.5 cubes net tuned 33Hz
2-15 inch AA Team subs D2
Americanbass- 750.1
1 yellowtop under the hood , 4 c&d 88ah batteries in rear
mechman-270
pioneer headunit-4200UB
4 soundqubed supertweeters
phoenix gold 2 channel
back up camera
stinger volt meter
22 years old and still have alot to learn..lets get it
Put a dmm on your amp outputs measuring rms voltage. Then play a tone or something and compare the output voltage when it "cuts out" to before.
That should at least eliminate that the problem is with subs or wiring....
Team NorthWestSPL
If voltage drops when the volume cuts out the problem is in the amp or signal path to the amp. If the voltage stats the same, your amp is still trying to put out power but something is up with your subs or wiring...
Should at least start to narrow things down, its where I would start.
Team NorthWestSPL
hope its not the same issue i had with my Sundown amps Good luck bro
:ninja:
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
:ninja:
sensai what problem did u have with ur sundown amps?
Americanbass- 750.1
mechman-270
back up camera
stinger volt meter
It may not be .5 ohm stable. I have a jl amp and when it goes into thermal protect it turns the volume down. I couldn't find the manual for your amp.
  • Who's Online   0 Members, 0 Anonymous, 689 Guests (See full list)
