DylanBunch Posted January 24, 2014 Report Posted January 24, 2014 hahaha alright sounds good man! 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
Hotdog Posted January 24, 2014 Report Posted January 24, 2014 Actually qts .5 or more do very well in a 4th order. Below .5 is the area to be concerned about however my subs have a qts in the .35 range and they do fine in a 4th order. (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
jarrius Posted January 24, 2014 Report Posted January 24, 2014 Its not that they wont work. They probly would and sound very well. It was that i was told it would cut the life of the sub in half due to the spiders design and the pressure from the sealed section of the box. But we will have are answer tomorrow i hope when they get back to me 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
jarrius Posted January 24, 2014 Report Posted January 24, 2014 Well I'm wrong (no surprise there) they changed from what they originally told me but here is the exact email they sent me so i do apoligse for my miss information Allen, Our woofers do great in a well built 4th or 6th however I wouldn't be able to help much other than our specs as I don't delve much into boxes of that type! 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
DylanBunch Posted January 24, 2014 Report Posted January 24, 2014 ive been waiting to get this out.... **clears throat** I TOLD YOU!!!!!! lol just playin bud. I between the stiff suspension and direct email i woulda thought the same thing 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
agf144 Posted January 24, 2014 Author Report Posted January 24, 2014 Well I'm wrong (no surprise there) they changed from what they originally told me but here is the exact email they sent me so i do apoligse for my miss information Allen, Our woofers do great in a well built 4th or 6th however I wouldn't be able to help much other than our specs as I don't delve much into boxes of that type! Thanks for the information I might be building a 4th this summer then. Now I just need to learn how to design one Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird.. He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke. 2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12 Amp: pioneer gm9061 amp: poineer gm9601 headunit: kenwood kdc 255u mids: SQ pro mids midbass: polk db 8s highs: stock mids/highs: shitty off brand
TZspeakersZac Posted January 24, 2014 Report Posted January 24, 2014 If you're going for a musical build, 2:1 is the way to go, but you might not want to tune the port below 40hz. Just personal experience, you'll cut off everything above 60 if you go that low. Personally, I'd tune in the 50's. If you like, I can give you a couple ideas. Nah man, it's cuz of the bass.
TZspeakersZac Posted January 24, 2014 Report Posted January 24, 2014 Also, you have HDS and NOT HDC, correct? Nah man, it's cuz of the bass.
DylanBunch Posted January 24, 2014 Report Posted January 24, 2014 i think your box volumes are good, best thing is to find the sealed resonance of your subs in that amount of airspace and then tune the ported side to the sealed resonance. If the sealed resonance is too high for what you wanna tune to you can add polyfill (about 1lbs per cbft) and it should lower the sealed resonance a bit. For port area you can start at around half the cone area, maybe a tad on the smaller side of half cone area. Ive also learned the hard way box strength is very important. Build a weak box and youll lose a shit ton of output. Hope it helps 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
TZspeakersZac Posted January 24, 2014 Report Posted January 24, 2014 i think your box volumes are good, best thing is to find the sealed resonance of your subs in that amount of airspace and then tune the ported side to the sealed resonance. If the sealed resonance is too high for what you wanna tune to you can add polyfill (about 1lbs per cbft) and it should lower the sealed resonance a bit. For port area you can start at around half the cone area, maybe a tad on the smaller side of half cone area. Ive also learned the hard way box strength is very important. Build a weak box and youll lose a shit ton of output. Hope it helps I could not have said this any better. Nah man, it's cuz of the bass.
