After setting gains with dd-1
Skax
i was wondering since its a 4channel should the high pass filter be on , on both of them or just one side and one side low pass and what should the actual lpf and hpf be set to ?
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
It depends on what speakers are hooked up and if you have any other type of crossover on other than the amp
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
all 4 door speakers and no i dont beleive so
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
wouldn't you want a full pass setting on all instead? What speakers do you have.
yea i was just making sure lol so high pass on all , what should the hpf and lpf (one u change with flathead) the other one i know should be switched to flat?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
If you have if switched to hpf the LPF dial doesn't function. If you have it switched to LPF the hpf dial doesn't function. If you have it switch to band pass then you want to set both hpf and LPF dials.
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
lots of sky high cable
dual alts(came off the sky-high gmc and don't know who made them)
ipad in center console
vu-din in center console
all being ripped out and being sold
ok so both of them should me switched to hpf what about the freq on it?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Start at 80hz and if it doesn't sound good then slowly go up. Some won't sound good until 125hz
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
  • Who's Online   0 Members, 0 Anonymous, 636 Guests (See full list)
