Possibility of cancellation with sub arrangement?
DylanBunch
So I have a plan for a b pillar 4th order and Im wondering if there will be cancellation if the subs across from each other on baffles parallel to each other? Might be an obvious answer but i wanna be sure. Thanks guys
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
LIke this?
___ ___
the top being baffle and subs being the underpart inside the enclosure?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
like if youre sitting in the car and you look through the port and see a sub on the left and a sub on the right and the baffles each sub is on is parallel to each other? Know what I mean?
2006 Ford Explorer
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
Yeah, that is fine. I forgot his name on here. But there was a guy with a 6th order with 4 z3 15's i believe, had it set up like that. Bitch wanged hard as fuck.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
you thinking about "youee" I believe that is how his name was pronounced.
what is it about the v shape that makes it better?
2006 Ford Explorer
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
I could be wrong but i guess that it off sets enough so that the waves glance off each other instead of a head in impact if you get what i mean.
Think of it this way take 2 garden hoses with the water running out both. Now put the hoses where the water is hitting itself head on and see what happens with it. It should smash in the very center. Now angle it a bit and you should see the water coming together as 1 stream. In theory i see sound waves should act just about the same ^_^.
Also if what i said is wrong please correct me i need to learn.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Dylan you sat in my mountaineer right ?
here was my 3:1 setup. 4 old school RFR2215 on 3000rms and it does 50+ on music. did a 151.5 with ZZ top and 153+ in the kick
  • Who's Online   1 Member, 0 Anonymous, 1727 Guests (See full list)
