New Member. Couple Qs
dropped11
Hi guys im new to the forum but am a long time lurker. A little background about my limited car audio experience, My current setup is a single SSA ICON 12 running 800w at 1 ohm off of a 'RE audio 1000.1 in a 2.25 cu ft. Box tuned to 32hz. Box was made myself using 3/4 mdf with liquid nails and clamps. Actually blew the lid off it yesterday. So I'll be adding some screws.
As for my questions. 1.my amp is getting pretty hot which worries me because I don't have extra cash to spare to replace it if it goes. 2. I actually just received the sub 5 days ago. So im still babying it and learning to tune my amp. So! How do you guys recommend I go about tuning my amp? I have a oscilloscope app on my phone and a test tone app also. Can I use those to get it pretty close?
Thanks in advance!
Forgot to mention I'm also running a sound quest LOC.
Seems like go the most part just tuning my amp correctly will fix my issues?
Also is it okay for the amp to get pretty hot? Can I mount it a certain way to dissipate heat better?
Its most likely getting hot because how its tuned
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Hello and welcome. Just like these guys said, you really need a DD1 at MINIMUM. Any set up youre going to change to in the future is going to need to be retuned from the front back too, so might as well spend the money to buy one. It's a great tool to keep in the tool box. Well NOT the tool box, but keep on hand.
To dissipate heat if you're really worried about it, I'd maybe think about raising up the amp a bit, maybe use rubber grommets between the amp and the mounting spot to put some space between them. Then a fan will always help move air under it. Otherwise, it's hard to say. Is it hot like so hot you can't keep your hand on it, or just warm or what?
Pics of mounting spot? Tuning it better is going to help a ton as well, like every one else said too.
Good luck!
I second what the other members are saying. My amp would get pretty hot, but after I bought a DD-1 and tuned it, it only gets warm now at best. The pics of where it's mounted would help too like Scooter said it's important to have a good amount of airflow around the amp.
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
  • Who's Online   0 Members, 0 Anonymous, 690 Guests (See full list)
