What to power SA10D2 under 250
lesstutrey
lol. ct sounds 900 will do 1k at a little under 13v. soundstream will do at at 14.4v.
in the real life, you wont be holding 14.4v. a drop to 13v or mid 12's is more realistic.
plus the ct sounds amp looks way sexier than anything soundstream has released lately.
edit: ct sounds amp is a tad smaller too, if you need the space.
I backed out. I got burned when i ordered RE (though not horribly i am ok with 320w @ 4ohm for 175$). I just look at the soundqubed and and CT and see really really weak 4 ohm ratings, which is what i'd like to run since i only have a 200a alternator on a 350sbc with standard pulley setup (not serpentine conversion) and only a single battery with current design.. so 1 ohm seems kinda outta the question for daily driver load.
Um you could run 1 ohm with dual batts.under the hood and the 200.amp
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
anyone have links to CT pricing...I only recommended the Soundstream due to the price, I haven't seen the CT pricing for the 900.1
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
double post
Alpine CDE-hd148bt
Alpine PKG-RSE2
Kicker KX350.4
DC Audio 1.2k
Notice you run orion amps. was looking at those too.. specifically XTR1400.. bit more cost than either the CT or SQ but much better 4ohm ratings.. is this something to consider?
  • Who's Online   1 Member, 0 Anonymous, 1129 Guests (See full list)
