ROLEXrifleman Posted February 11, 2014 Author Report Posted February 11, 2014 one of the many tools needed to properly "clamp" test an amplifier I might even go out on a limb to say the most important Rolex you sicken me. Just let me finish my pie ~ Juice
ROLEXrifleman Posted February 11, 2014 Author Report Posted February 11, 2014 Bought would should be the last of the hardware. Mock up to test fit as usual Rolex you sicken me. Just let me finish my pie ~ Juice
Kyblack76 Posted February 11, 2014 Report Posted February 11, 2014 DAMN nice kid..... damn nice I bent a piece of lexan to go over my battery, (was gonna use it as a fuse holder) and in 2 days, the heat from the motor had it so warped, i had to cut it to remove it..... But, i dont think youll see those temps?!?! Shit looks tight bro. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted February 11, 2014 Report Posted February 11, 2014 im sorry i feel like an idiot but what is this for? To get proper numbers, you would need a "load". Like the driver. Or,.... make a resistive bank. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Jessica Posted February 11, 2014 Report Posted February 11, 2014 But wait. I just saw a thread that had clamping at the same time as a dyno and the clamp was wrong. Not sure where that thread is now or what the explanation was. Cool project just the same. Tuned in Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
ROLEXrifleman Posted February 11, 2014 Author Report Posted February 11, 2014 please find that thread. There is no difference in clamping an amp with individual tools or with the AD-1. The fact is the majority of people clamping are not doing it properly and trying to pass their findings as accurate. Notice how I said accurate and not correct. There is no correct reading on any given amp as all amps are built with electronics that function to a given tolerance. Thus 10 out of 10 amps within a given model will all give different measures. case in point, Any RF Punch amp from the early 90's (or even today). Pick up 10 birth sheets from the same model and you have 10 different numbers. None of them are correct or incorrect, they are all accurate readings of what that amp can do. In addition, there was no AD-1 in 199X, does that nullify the readings on those birth sheets some of us live to gloat about? of course not. Simply put the term "CLAMPING" has been associated improper procedure and thus now has a negative connotation associated with it and then there are those who are just ignorant to those procedures and continue to follow the half asses methods that flood you tube and message forums such as this. The truth is out there, people just have to sift through the trash to get to it. If doing things right was easy no one would do them wrong! Rolex you sicken me. Just let me finish my pie ~ Juice
ROLEXrifleman Posted February 12, 2014 Author Report Posted February 12, 2014 Final stages, I can see the light at the end of the tunnel! cleared board of resistors peeled off protective film and started laying down grommets after 8 grommets were laid down I pulled the wires through and peeled back stripped ends to get ready for connection to resistors just needs a little windex! connected to resistors via screws nuts and washers. was there an easier way, sure but this was for love not convenience. Lay it down and attached with two screws two nuts and two washers now I just have to repeat this 7 more times!!!! Rolex you sicken me. Just let me finish my pie ~ Juice
alaskanzx5 Posted February 12, 2014 Report Posted February 12, 2014 looking good. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Jessica Posted February 12, 2014 Report Posted February 12, 2014 please find that thread. There is no difference in clamping an amp with individual tools or with the AD-1. The fact is the majority of people clamping are not doing it properly and trying to pass their findings as accurate. Notice how I said accurate and not correct. There is no correct reading on any given amp as all amps are built with electronics that function to a given tolerance. Thus 10 out of 10 amps within a given model will all give different measures. case in point, Any RF Punch amp from the early 90's (or even today). Pick up 10 birth sheets from the same model and you have 10 different numbers. None of them are correct or incorrect, they are all accurate readings of what that amp can do. In addition, there was no AD-1 in 199X, does that nullify the readings on those birth sheets some of us live to gloat about? of course not. Simply put the term "CLAMPING" has been associated improper procedure and thus now has a negative connotation associated with it and then there are those who are just ignorant to those procedures and continue to follow the half asses methods that flood you tube and message forums such as this. The truth is out there, people just have to sift through the trash to get to it. If doing things right was easy no one would do them wrong! pretty sure it was CJ, but i will look,. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Jessica Posted February 12, 2014 Report Posted February 12, 2014 This one Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
