Building Idler Pulley Bracket..
Alright, so basically Im building an idler pulley bracket.. But am lost with what material to use. I was thinking of just using sheet metal, but don't know what thickness to get. OR, is there something else I should use?
Here, let me explain more of what Im doing...
Here's my factory alt bracket:
I plan on using the bolts that are blue as my mounts for the idler pulley bracket:
Here's where the mounts will be (when bolted on to the engine):
Its a bit odd to explain this, but basically the sheet metal will have 3 holes- 2 to bolt on to the alternator bracket and one for the idler pulley.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Use one of the holes and a bolt with the pull on it. Don't over complicate it. You'll be hard pressed as.is to line it up right.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Also just about any way you route that it's going to give you less belt wrap even if you did two pulleys it doesn't sit well with me tbh
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
One of what holes? The blue ones? I would, but I can't fit a pulley big enough with the stock idler. I would remove the stock idler, but wouldn't my crank pulley suffer (the right most pulley)?
LMFAO so true
:blush:
Fuck, Ill draw my idea and post the pic here
LMFAO so true
:blush:
So, heres a quick sketch..
The yellow is the bracket. When its built, it'll be "full"
The red is the new bearing.pulley.
The green is an idea of the new belt wrap.
LMFAO so true
:blush:
Ah ok. My bracket for my duals is 1/4 inch thick plate steel. Not Sure Of What Material Though
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Sweet, thats what Im trying to figure out.
LMFAO so true
:blush:
Move the big idler kid !
LMFAO so true
:blush:
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
