i'm new, can somebody plz check this box design?
Don Fiesta
All dimensions look exactly correct, I did slant the extension parts on the inner end, can also be rounded just like in the opposite end. Great sketch, the harder part is cut as accurately but if you are careful you will manage.
oke, thank you very much for all your help! i really appreciate that!
i think im going to round the extensions as wel.
i will start a build topic on this forum and put the link in this topic so you can see what im doing and ill let you know how it sounds!
thank you, thank you, thank you for helping me!
grtz!
1question, how should i wire my subs? im going to play them on 1ohm..
i know its all negative together and all positive togther but i want to knwo the best way to come out of the enclosure with my wires..
1890500_10201585920236178_367318833_o.jp
I used binding posts on mine. These are Dayton satin nickel binding posts. They are a lot better than the terminal cups for high powered systems. Some people just use bolts and nuts to simulate binding posts. These cost me $8 a pair.
2 - Sundown SA 8V2 | CT Sounds 1400.1 | Pioneer DEH-X8500BS | 4/0 Big 3
Yes bolts and nuts, additionally you don't need to solder, the amp has two positive and two negative terminals, you can use one set to each sub.
so, wire each sub to 2ohm and connect each sub to a channel?
Yes wire them like that. That will give you a 1ohm load. I would use at least 12awg wire to go from amp to sub. I'm running 10awg to my sundown sa 8v2. It's overkill but you can't have too much copper.
  • Who's Online   0 Members, 0 Anonymous, 1030 Guests (See full list)
