Swordlordboy1234 Posted February 8, 2014 Report Posted February 8, 2014 All the way forward would be acceptable. If you had a 90degree angle seat back and the whole seat slid forward maxed out then you would still be stock class. As long as the seat stays in and your enclosure doesn't stick out horribly. Keep in mind, all amps and stuff have to be in "stock" locations.. So I don't think you can put them anywhere except behind the seat. If it was me I'd just do a super stock build and take the back seat out, much easier to work with. Below the window line and behind the b pillar My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
KenC210 Posted February 8, 2014 Author Report Posted February 8, 2014 Stock Locations for the amps? My truck has a factory truck has the upgrade sound and the factory amp is under the passenger seat. So the amps and things would have to be located there? Since it does have the factory amp and was planning on keeping the factory radio i would need a processor. But if i have to have everything behind the rear seat then you are right everything would be extremely difficult to stay in a stock class. Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
